2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
What result would I see if I replace my stock mufflers with Harley cvo screamin eagle exhaust mufflers
Old 05-22-2017 | 07:21 AM
Roadtwister's Avatar
Roadtwister
Default What result would I see if I replace my stock mufflers with Harley cvo screamin eagle exhaust mufflers
I'm looking for a little more sound from my stock 2014 Road King, but do not want a loud exhaust for long distance touring. I see ebay has several for sale almost all the time. so again, my question would be, would I have a slight improvement in performance and a better sound than a stock exhaust. tks
Old 05-22-2017 | 07:46 AM
Cygnusx51's Avatar
Cygnusx51
Change would only be in sound since everything else would still be stock (air intake, heads, head pipes, tune, etc). Can't comment on the sound of those mufflers by the way.
M Oclaf (10-03-2023)
Old 05-22-2017 | 08:10 AM
Just Me's Avatar
Just Me
There may be a slight increase in performance but you wont notice it.
Sound is a deeper tone but like all mufflers they get louder with use.
Very nice looking muffler and still legal if you get checked with the stick.
Old 05-22-2017 | 08:46 AM
benningtonr's Avatar
benningtonr
I wanted the same thing for my 14 limited, just little more sound. I went with the Screamin eagle street cannons, a little louder but not obnoxious. you can get them on ebay used for 100-150 bucks
Old 05-22-2017 | 08:58 AM
'05Train's Avatar
'05Train
I run a DX headpipe with stock CVO cans. It makes for a nice, low, quiet sound.
Old 05-22-2017 | 09:30 AM
Magnut1's Avatar
Magnut1
Very little actual performance gain, like as said, you aren't changing anything else. To "see" or feel performance gains, you have to take a 3 prong approach. You need to get more air in, more fuel, and more air out. Intake, tuner, exhaust, basic Stage 1. The most you will notice on just changing exhaust is sound, but not that much with what you are planning. You will still run lean, still have the lag in your throttle, and still breathing through a restricted intake.
If you look at CVO or stock mufflers, through the inlet, there is a ramp that takes exhaust "sound pulses" and throws them around and into the glass mat sound deadener surrounding the baffle, and into the perforated chambers, and finally to the outlet. I had V&H mufflers, loved the sound but they rusted and someone had CVO stock mufflers. I installed them. I enjoyed the quieter sound for a while but missed the Harley sound. I pulled the caps off, ground out the welds and took out the baffle. Unwrapped the sound deadener and discarded it. Maybe 1 db louder. Still not satisfied, I pulled them out again and cut them just after the ramp and reinstalled the end section, with the 2" hole. Now it sounds like a Harley again. Oh, and I have a Tmax with auto-tune so the tune takes care of itself.
Old 05-22-2017 | 01:50 PM
RFG7680's Avatar
RFG7680
I put stock CVO mufflers on mine when it was all stock. Biggest change was how they look. There's no noticeable performance change. The tone changes but they're not louder. But. You can put in fullsac baffles. That's what I ended up doing. 2" baffles with the steel wrap and I gutted my cat. Sounds great.
Old 05-22-2017 | 04:50 PM
Roadtwister
Great suggestions! I will look for some Harley street cannons, or SE on ebay, etc. Thanks!
Old 05-22-2017 | 05:42 PM
larry bart's Avatar
larry bart
If you get the older CVO cans they will have catalyst in them. I used a pair I found and installed fullsac 1.75 baffles. If I do it again I will go with the 2.0 for a little more sound.
Old 05-22-2017 | 06:44 PM
OldMike's Avatar
OldMike
I have the CVO mufflers on my 2014, they are part of my Stage 1. I also have a Fuel Moto head pipe, K&N air filter and Power Vision tuner.
The CVO mufflers are louder and have a better tone than the stock mufflers, they get louder after break in. My bike runs great, love the sound, have been running these for over two years. I don't want anything else since they are a comfortable volume at highway speeds, comfortable like the rest of the bike.
You want noise, get something else.
Quick Reply: What result would I see if I replace my stock mufflers with Harley cvo screamin eagle exhaust mufflers
