Heated Grips won't turn off
Hello,
I just installed a new set of handlebars and while I was at it, I installed a set of HD heated grips. I've had these grips on previous bikes so I'm familiar with them. Here's the problem. As soon as I started the bike for the first time after buttoning everything up, I noticed that the grips were getting warm. I checked and the rotary dial is set to "0". After a bit of experimenting, I can't get the grips to turn off no matter what setting they are on. Anyone had this problem before? There's really only one way to plug the wires in since they have male/female sockets correct? The left grip has two wires. One goes to the power plug on the left side of the fairing. The other wire connects to the right side wiring that feeds back up to the Throttle by wire.
Thanks for any ideas.
Dave
Dave
Hmm. Now that I've had a chance to get home and look at the service manual, I see that both the power connection under the fairing AND the interconnect coming from the right grip both have a female two place Tyco 40 connector. So I guess I may have connected the left power wire to the right grip interconnect and the left interconnect wire to the power connector. Would that cause them to be on always? It was a bit late last night and I was in a hurry and tired when I made that connection. Typical situation for a mistake. I think I just "***-umed" that the connectors would be different to make this mistake impossible to make.
The Pawnbroker (05-11-2017)
I did run them inside the bars but didn't take off the connectors. I "thought" one was male and one female so I didn't need to check too closely. However, it looks to me like the wires coming from the left grip are both male according to my reading of the factory manual's wiring schematic. I will admit I'm not an expert at wiring. So maybe someone else will confirm?
Here's a post I did back when I did mine, shows the connector locations...
https://www.hdforums.com/forum/touri...l#post14752098
Good luck
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
Good luck
__________________
NO, they DON'T all do that!
Also on amazon.com...
The Pawnbroker (05-12-2017)
