Tour-pak lighting harness help.
This harness from Namz is the one that will plug into your current bike (2014 and up) under the seat, but the tour pak side will need to be modified to fit a pre Rushmore Tour pak harness.
But then again it could be overkill for just sde marker lights. This harness will give you running lights, blinkers and power for a power port.
https://www.namzcustomcycleproducts....g-models-only/
[QUOTE=timbo141;16127339]This harness from Namz is the one that will plug into your current bike (2014 and up) under the seat, but the tour pak side will need to be modified to fit a pre Rushmore Tour pak harness.
The Namz harness was what I thought I needed.
You are right about overkill. I may just tap into a power source under the seat and run two wires back to the tour-pak. Thanks for your reply.
Robtarra39
2014-2023 Touring Models
09-05-2016 05:38 AM
VTwinJaxFL
01-19-2015 11:35 AM
