Can receive cell audio, but caller can't hear me.
Can receive Phone calls, and caller can hear me, but I can't hear them.
I have a 2015 Ultra-Limited w/Boombox that was working fine. Now when I receive a phone call the caller can hear me but I can't here them.
~Checked using a different headset to make sure that wasn't the problem, same thing occurred.
~Checked to make sure headset was the audio source selected to receive audio, Headset is selected.
~Checked that audio was not muted. Oddly, in checking Audio status via menu, it shows "mute" So I select "unmute" exit out, but then when I return to that menu "mute" is displayed again, I'm pretty sure unmute means not muted. At least that is what manual says.
~Using another phone had caller talk while I tried to adjust volume up (volume adjust must be done while call is in progress and person is speaking) volume is all the way up.
worked fine before, baffled as to what happened/changed.
dealership had no suggestions.
any trouble shooting ideas/suggestions are appreciated. Thanks
I tend to agree this this suggestion. Sounds like the update probably just reset the factory defaults on volume.
Good luck hopefully all is good moving forward.
Check the following
Are you plugged in to the front or rear because each has its own volume control.
I would make a call and when I see I’m connected raise my volume to see.
If you have a cordless house phone bring it outside to bike and call your cell then play with system.
Make sure your volume on your phone is up to max.
