In the picture i attached is it connector 9, what connector goes into it, sorry for all the stupid questions, but dealer who installed it said they never seen this before and even called there tech net and found nothing
There are no stupid questions. Glad you got it figured out.
Yes, #9 is what you're looking for. 2 wire black connector, probably has a dust plug in it that you'll need to remove. Brake side, top portion of fairing.
So i got the Y connector, just need to know what pugs go in all 3 , i am gessing one end goes to the P&A plug to the left of the radio, what goes into the othe 2 plugs of the Y connector
IIRC, The single end goes into the P&A plug, one end of the Y will tie into the amp harness (after you unplug it from the other power source in the bottom right of the fairing) and the other Y is just a handy dandy spare for anything else down the road.
Thx for your help Roadie13, dealer had it plugged wrong, moved the plug up as you said and now amp is on when swtich is on acc
