Narrow Heel Shift Pad
I just added on a set of Kuryakyn 3/4" floor board spacers. Looking at the stock heel shift pad I'm wondering if there are narrower pads available for the heel shifter. The stock is 2" wide if I could find a 1" or 1.25" wide pad, the floor boards would become pretty spacious. I like to use the heel shifter when I'm stopped and locating neutral. I mainly shift with my toe both up and down. Just not sure if I want to ride without a heel lever.
If I could find a source for a shorter shouldered bolt, I could narrow up the pad as well.
It's a shouldered bolt. I'm going to see if I can drill it out and tap threads into the end so a small machine screw and chrome washer will retain the rubber pad.
ilikethewoods
04-26-2011 06:16 AM
