Anybody burning turn signal light bulbs excessively?
I have a '16 RGS and have had 3 rear left and 1 rear right turn signal light bulbs burn. This seems excessive and concerns me that there might be some issues. I'm probably going to take it to the dealership to have it looked at but figured I'd ask before they tell me there is nothing wrong and have not had any reports of problems.
markfsanderson (01-24-2017)
Back when I used to play with airplanes, we tracked reliability of the AC (AC=Aircraft) by pilot write-ups . When we noticed excessive usage on Landing Lights or Taxi lights we would take a closer look at the AC. By just slowing down and focusing on things like clamps and mounting a lot of times we could solve the issue. Other things were Mods to the AC from prior owners that then required a different PN bulb/clamp/wiring connector.
So, I would start with the basics.
-Is the rear turn signal mount and bulbs the correct PN. HD Bulb #68163-84 for the FLTRXS.
-Is the Turn Signal mount secure?
-Have any Mods been done to the Mount or license plate that might cause a vibration when riding?
-Have the rear shocks dampening rate been adjusted?
-Is the Tire at the right pressure?
-Has the rear tire/wheel been properly balanced?
Since you noted that this is a 2016, are you still under Warranty. If so I would get the dealer involved. I know that typically bulbs are not covered, but in your case they should have some skin in the game trying to sort this out.
Also, I see you are in FLA. Have you noticed any corrosion in the bulbs contact area.
Like a lot of the other posters, I cannot ever recall changing a turn signal bulb on any of my Bikes.
If you are replacing the bulbs with ones from a local supply house (PEP,Autozone,etc) I would at least try the HD supplied bulbs.
Hope this helps.
Rotor
Hope this helps.
Rotor
