2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Stealer says $1k For Handlebars?
Old 12-29-2016 | 02:25 PM
gigihurt's Avatar
gigihurt
Originally Posted by lyork
What about doing bars with factory heated grips?? Anyone done those ?
Yes Mine has factory heated grips. done it christmas day.
Old 12-29-2016 | 02:26 PM
gigihurt's Avatar
gigihurt
Originally Posted by Magnut1
From what I understand, some manufacturers that sell bars say to cut like 3/8" or something like that off the left bar if you are installing aftermarket.
1/2" is what is recommended by the video.
Old 12-29-2016 | 02:40 PM
Ganooch's Avatar
Ganooch
That is actually cheap. I was quoted closer to $2K without the bars themselves. Hourly rate is higher than $98 here too. Just do them yourself. My 14s took about 6 hours and it was my first time doing it. Take your time, do a ton of research, ask for help here when you get stuck. Then think of other ways to spend that $1K you saved by turning the wrench yourself.
Old 12-29-2016 | 04:35 PM
Wildon883R's Avatar
Wildon883R
Thats not unreasonable for what it takes to do especially for a novice or less mechanic which makes up about 99% of all Harley riders. For the Arm chair mechanic/bikers 6 hours would be a great time if you were skilled or proficient at preforming the task. Watching a how to video and actually do it are two different things. The dealer can charge what the book says like what the book said when i was a certified ASE auto tech. That book actually screws mechanics with time standards on alot of jobs that can't be completed in the listed time. There are probably less than 1 out of 10 members here can can disassemble an electrical connector on our bikes. To the person that said they can do it in two hours i say BS especially if your not a HD tech that has done it over 100 times before.
slowrollin (12-30-2016)
Old 12-29-2016 | 04:43 PM
lp's Avatar
lp
Having done this job about 20 times I could do them in under 3 hours easy. That's with new hydraulic lines...
So much easier now with CANBUS too. "Back in the day" it was a mess getting 10-15 wires through the bars. Now it's like 2 or 6 with heated grips.
Not a hard job. Dealers are out to make money. Hard to blame them for charging so much. Keeps the doors open I guess.
Old 12-29-2016 | 06:41 PM
nevada72's Avatar
nevada72
20 times?? Wow! You either go through bikes like I go through socks or your garage is full of beer from helping out all your buddies.
lp (12-29-2016)
Old 12-29-2016 | 08:17 PM
Longridertx's Avatar
Longridertx
I put WO 578's on my Ultra in about 3-3.5 hours, including new urethane bushings and that was taking my time to do it. Taking the wire connectors apart isn't hard at all. I watched a you tube video of a guy doing it on a Streetglide a few times where the guy showed how to take the connectors apart and it was really pretty easy. Just draw a pic of the plug, label each hole on the drawing with the corresponding wire color. take it apart and the wires pull through easy. I think it's more intimidating for a 1st timer than it is hard to do. Now on some bars I could see it being a PITA.
Old 12-29-2016 | 09:18 PM
sammer4u's Avatar
sammer4u
Do you happen to have a couple photos of your bars? I am thinking of same setup on my bike.
Old 12-29-2016 | 09:19 PM
Ganooch's Avatar
Ganooch
Simple fact is that they charge that much because people will pay that much. Even though I do my own bars, it is time consuming. There are a lot of Harley riders out there with the money to pay just to not have to be bothered with it. Also, there is a lot that can go wrong. A 6 hour job can quickly turn into a 10 hour job when you have to pull everything back apart because a wire is crimped somewhere, or a connection isn't seated properly.
Old 12-30-2016 | 12:21 AM
matt76cmich's Avatar
matt76cmich
Do it yourself and save over 50% of that. I still used my stock clutch and brake on my 2015 when I did my 14" KST Mayhem Bagger Bars.
Attached Thumbnails Stealer says alt=k For Handlebars?-screenshot_20161230-011857.jpg
Quick Reply: Stealer says $1k For Handlebars?
