Rico LED Headlights in 2016 StreetGlide
I replaced the stock lights with the Rivco LED-120. Which is a two bulb set to replace the H-9 and the H-11 bulbs, with fan cooled LED's.
New bulbs are the same so doesn't matter which is high or low beam. I confirmed this with Rivco.
On low beam I have a bright spot close to the bike and another one much farther down the road. When I switch to high beam which turns on the other bulb along with the low beam bulb, the light farther down the road doesn't get brighter. Rather it fills in the darker spot between the near and far lighted areas.
The pictures are first low beam then high. Anyone else using these Rivco lights with same results? Just not what I expected.
RK14SGS
2014-2023 Touring Models
10-22-2015 03:13 PM
