street glide tour pack lighting
I bought my plug and pins for my 2010 tour pack I got. Then used my Custom Dynamics splices from my Plasma Rods by the bags to hook up Brake and Tail Lights on the rear, they do not function as turns on mine. (You can by a module that will do it I know) Check out Customdynamics LED kit for older tour packs. My Plasmas really light the rear up for turn and brake. I mostly wanted to have more tail lights and the LED bar on the bottom sides to work. Brakes on pak ar a bonus.
As stated by Roadie13, Namz makes a wiring harness that plugs into factory light connection under seat. It will supply run, turn, brake, and power outlet power to tour pack.
NTP-CB01 is part number that connects to 2014 and up touring bikes.
http://www.namzcustomcycleproducts.c...harnesses.html
There are a couple threads on this if you do a search.
Once you get the wires up to tour pac you will need to do some wiring. But at least you dont need to cut any wires on the bike. Just unplug factory connection and plug both ends to the NTP-CB01 harness.
Thanks for everyone's input it's been very helpful will let you know when I get the pieces together and hoe it goes
Got this in the mail today thanks for the lead to Namz I talked to Tyler and he hooked me up. I am still waiting on the pins to wire in the tour pack. Namz only sold the pins 100 per pack so i ordered the pins from a different company. by the way harley sells the pins 5 dollars each I paid .08 cents a piece for them plus 9.00 shipping.
