2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Front fender skirt removal
Old 11-23-2016, 10:38 AM
dspencer's Avatar
dspencer
dspencer is offline
Default Front fender skirt removal
Just curious if anyone has taken off the front fender skirt of a Ultra limited and left it off. Mine is looking a little ragged and I thought about replacing it with a nice chrome one. I sometimes run the bike without the tourpack so a nice clean fender (like SG) might look nice. The problem I see is the little holes that would be left if not replacing the fender skirt piece. I haven't taken it off yet so looking for collective knowledge from this site. Thanks for any input
Old 11-23-2016, 02:26 PM
Oogie Wa Wa's Avatar
Oogie Wa Wa
Oogie Wa Wa is offline
I added a mud flap on mine on a '14 Tri Glide, if that's what you mean by skirt; at the bottom/back. Took out the 5 teeny tiny itty bitty screws/nuts. Yes, those little holes and some gunk on the fender, but I didn't look to see if the skirt marred the paint or not, since I was putting it back on.
It will come off with a small screwdriver and a tiny wrench (I used a 4" Crescent hammer) without taking off the wheel. Putting them back was a pain, make sure you use some Loctite on them if you do.
Old 11-23-2016, 06:49 PM
dixonk's Avatar
dixonk
dixonk is offline
Received 7,508 Likes on 3,579 Posts
There is more than just a hole. The front fender is actually indented in the front as well to accommodate the light. I scoured eBay and found a take off street glide fender for 100 bucks.
Disregard my reading comprehension is low today. Saw you were referring to the fender skirt not to the fender tip.
Old 11-23-2016, 08:01 PM
lp's Avatar
lp
lp is offline
Received 2,829 Likes on 1,592 Posts
I think the only visual problem is that without the skirt the fender looks a little short in the back - because it's shorter than an SG fender, but if that doesn't bother you, cool.
Old 11-24-2016, 12:51 AM
Steel Wheels's Avatar
Steel Wheels
Steel Wheels is offline
Aesthetically, the fender doesn't look good without the skirt. I know from replacing mine that the chrome jobs add more than a little rigidity to the fender also.
Just my two cents worth.
Old 11-24-2016, 06:53 AM
santajim's Avatar
santajim
santajim is offline
I had to replace my skirt so I went with the chrome one that came out last year. It is a lot nicer looking than the original and there will be the holes left if you leave a skirt off.
motoXjoe (11-27-2016)
Old 11-27-2016, 06:14 PM
Oogie Wa Wa
Plus there is the mud and stone chip thing. The whole reason I knew what it was like to take it off was so I could add a mud flap in the first place.
Old 11-27-2016, 11:57 PM
motoXjoe's Avatar
motoXjoe
motoXjoe is offline
You mean this chrome one? Looks much better than the stock one that came with it! I'm swinging by the stealer to pick one up tomorrow. Thanks SantaJim!
http://www.harley-davidson.com/store/front-fender-skirt
Old 11-28-2016, 08:42 AM
Harttoo's Avatar
Harttoo
Harttoo is offline
Look closely at Your oil cooler cover and notice the stone damage.Running with out a skirt will cause the damage to go up higher.
Old 11-28-2016, 11:08 AM
dspencer's Avatar
dspencer
dspencer is offline
Thanks Guys- I'm going to go ahead and replace with a nice chrome one.
Quick Reply: Front fender skirt removal
