Passenger backrest
Passenger backrest
Had a 2011 SG & bought a 2016 SGS back in Aug.On the 2011 I had the two point docking hardware & pass. backrest & it fit perfectly.Took that off of the 2011 & installed on the '16'(docking hardware).Just tried to put the pass.backrest on & it wont fit.The docking part is set to far apart on the 16.Anybody else have this problem?Did they change the backrest dimensions on the Rushmore bikes or change up the docking hardware?Anybody have a clue?
piper59 (10-31-2016)
The docking hardware changed for the Rushmore models, but the backrest should still fit. My 2011 Roadking backrest fits on my 2016 FLHTP.
On the Rushmore models you have to adjust the black plastic thingies by loosening the bolt and rotating the black plastic part until the detachables fit. They usually have enough adjustability for the detachable backrest to fit from too loose (it would rattle) to too tight (not fully lock on). I'm assuming the holes are drilled thru the black plastic part slightly off center to allow for the adjustment.
On the Rushmore models you have to adjust the black plastic thingies by loosening the bolt and rotating the black plastic part until the detachables fit. They usually have enough adjustability for the detachable backrest to fit from too loose to too tight. I'm assuming the holes are drilled thru the black plastic part slightly off center to allow for the adjustment.
