I have turned my passing lamps over for better lighting in corners. I'm wondering if the dealer can program them to only come on with the high beam headlights.
The default setting is only coming on with the low beams. I had mine reprogrammed to stay on all the time. I've not heard of anyone having them set to only come on with the high beams.
So have the flash done to allow the driving lights to be on with the High beams. That is the mod- factory default, or override it to allow with hi beams.
Push the little button the turn them on and off whenever you like.
Problem Solved
You're correct, my mistake as I misread the OP. Thanks for the clarification.
Actually yea you can have it set to on with high beam only. I had my buddy at harley set it that way on mine because my fog lights are to bright to be on with the low beam.
