Aftermarket Rotors
Aftermarket Rotors
The rear rotor on my 14 RK has been warped for a while now and I'm looking to replace it. While going with the stock rotor is a possibility, considering how easily it warped in the first place, I'd like to look to the aftermarket for a better choice. I really don't want to spend a small fortune on a rotor, but am looking for something better than stock. I did a search, but didn't come up with a whole lot. Does anyone have any suggestions? Thanks in advance.
Chris
Chris
dane_ax (03-23-2020)
When you put the EBC rotors on your bike, did you have to use the stock HD spring things between the rotor and the wheel or was it a direct bolt on? I'm guessing that you had to either reuse or buy new springs.
This thread is over 3 1/2 years old - who knows, if the O is around to respond to you
Received 14,667 Likes
It happens to newer forum members who are seeing posts for the first time, and it happens to people who search a topic then don't notice/pay attention to the dates of the threads their search brings up....
Every once in awhile I'll answer a resurrected thread and feel a little silly being caught by it.... but it keeps you on your toes...
Buster (02-26-2020)
I knew it was older but I was actually replying to a tread where someone was going to a single rotor set up so not sure how it ended up in this thread. I searched the forums and was hoping to get a reply from that OP to get his thoughts on the single disc set up now that he had been running it for a few years.
