View Poll Results: What is your typical: Hot, No Load, Idle, Oil Pressure as shown on your "i" Information Sc
6 PSI or Less
5.94%
8 PSI
1.98%
10 PSI
6.93%
12 PSI
29
28.71%
14 PSI
41
40.59%
16 PSI
7.92%
18 PSI
4.95%
20 PSI
0.99%
22 PSI
0%
24 PSI or More
1.98%
Voters: 101. You may not vote on this poll
"Normal" Hot, No Load, at Idle, Oil Pressure
What is your typical Normal, Hot, No Load, Idle Oil Pressure?
MoCo has replaced the Oil Pressure reading on the "i" Information Screen on the 2017 bikes with what amounts to a Text version of an idiot light. "OK" or "Not OK"
I would guess that they have done this because showing the actual Oil Pressure has caused more customer complaints than it solves. Sort of a Too Much Information (TMI) problem for some folks.
Anyhow, in an effort to figure out what actually is "Normal" on the Wet Head Rushmore Bikes please answer this poll and then we'll all know the range that "Normal" actually is.
Please select the number in PSI that you typically see on a Warm to Hot Day when the Bike has been running for at least 30 minutes or so at an Idle. For what it's worth, mine usually reads 13 PSI. Becuase these Polls are limited to 10 selections I used increments of 2 PSI. If like me, yours is an odd number; pick the selection above or below it . . . your call.
Received 3,988 Likes
