Mustang Wide Tripper Solo & Pillion
Mustang Wide Tripper Solo & Pillion (review)
Hey guys, just purchased, and mounted the Mustang wide tripper solo, with a pillion. From a looks standpoint, I admit I'm biased. You'll have to judge for yourself there. I will say, though, Mustang quality is phenomenal! The fit and finish, and the build quality, are absolutely flawless.
Speaking on fit, it is more narrow than the stock streetglide seat. This gives shorter riders a little more reach to the ground. Height, is about the same. As is the seating position. I did not have to adjust my mirrors at all. If you've ever sat on one of the Screaming Eagle SG/RG seats, it sort of feels like that. It utilizes a much more dense foam. The stock seat is nice for a couple of hours, but, after that, you feel the hot spots. I've only ridden with this seat now, for a couple of hours. So far, I do not feel fatigued at all. Apparently, they use a fiberglass pan, that remains rigid for ever It also has rubber boots (I don't know the technical term for the footers) that supposedly isolate better against vibrations. I'm basically paraphrasing J&P Cycles review there. Which, I might add, has a 5 star rating for 80+ reviews. This seems to be the best all around touring seat, for those of us that want a sleek look, but need better comfort. I guess I'll have to ride with it on a little longer to fully judge that claim. But, so far, I'm very impressed.
You are now free to move about the cabin. Sorry about the turbulence
MTBIG G (09-30-2016)
Bafflingbs (09-30-2016)
I got out and rode a little today. So far, here's my non-biased review. First, I'll have to correct myself a little. The ride height seems to be a little higher. Say, maybe 1" higher, and because it's more narrow than the stock seat, it felt the same height. It may sit me back just a little further, which would explain why I do not have to adjust my mirrors. But, it's only maybe 1/2- 1" Back.
Now, as far as comfort goes, it's harder, and conforms to your butt, while giving more of a memory foam type feel. It seems to do a good job of eliminating hot spots. You do not simply sink in to it like the stocker. I've also noticed that what the J&P Cycles Youtube review says about the footers isolating vibrations is very true. In fact, I've noticed that the minor road imperfections, that I once felt, are no longer noticeable. And, the larger bumps, seem to be soaked up much better. It almost feels like I was riding directly on the frame, with the stock seat, and now I'm on a hammock above it. I have noticed one thing that annoys me; the back of the seat is raised, I assume, to give some support. Well, that attempt is poorly executed. It doesn't give any support, and in fact, is a bit irritating on my tailbone. I only hope, that like the rest of the seat, that part will break in a little. Still, if I were planning a ride longer than 3 hours, I'd choose this one, without a question. The stock seat is fine for short hops, but, as you all can attest, you soon begin to feel all the pressure points and hot spots. It's too soft, and extremely uncomfortable, to me, past 3 hours. Actually, 2 1/2 hours... I do not foresee that happening here. I also think that because it's more narrow, you won't have the ache and lack of circulation at the top of your hamstrings and inner back thighs. If I were to do it all over again, I might go with the same seat, with the back rest built in. Though, I've never used a back rest, and have no idea how that restriction would feel.
B.K. (10-05-2016)
https://www.denniskirk.com/danny-gra...29.sku#reviews
