Daymaker install on a 2016 Road King
For the Road King, no it's not plug-n-play simple. The harness will plug into the Daymaker just fine. To connect to the bike electrical system, some splicing will be required. Not difficult, just take your time. The harness should have come with what you need to complete the splices. I used plenty of electrical tape myself and then shrink wrapped them (soldering the connections would best to avoid them coming loose, followed by tape/shrink wrap). Here is a link to the directions.
https://hogworkz.com/blog/harley-daymaker-install/
if you don't want to make your own adapter here isa a link to an adapter.
http://innovativewiring.com/?page_id=4464
Scroll down to the H8/H11 to H4 about 3/4 of the page down. Works like a charm.
I hope this helps.
I hope this helps.
I hope this helps.
I hope this helps.
H8/H11 LOWBEAM / 9005 HIGHBEAM TO H4 WITH RELAY
No.
http://innovativewiring.com/?page_id=2487
This is the one.
I am running a Chinese knock off and both the hi and lo were on with the stock bulb so they are on now. So far so good. Not as much heat from led as from H4 halogen.
I hope this helps.
This is the one.
I hope this helps.
cruzmisl
07-20-2014 08:41 PM
hdlurker
09-08-2013 11:27 PM
scottlabrecque
11-01-2005 02:00 AM
