How can I get my SG to ride like an Ultra...?
#31
I just put the heavy duty 944s on my Road King and I have noticed a difference in the ride. I still have to set the correct sag but just out of the box it was an improvement. The Ultras do have that nicely padded seat but I cannot see myself putting one on my RK. As BigMike and TwoLaneTramp have stated, you need to look at a different wheel/tire up front and different seat (once you set the sag correctly on your 944s if you have not done so already). And a little ballast should help as well because I have heard that the progressives ride even better when 2 up. If none of that works, I hear the 2017 models are great. Good luck.
I put a RK Sundowner on my RK looks so much better than the factory seat, also rides so much better also.
#32
Don't forget how much tire pressure can change the ride . I had a buddy who rode a rigid frame for years and only ran 25 psi on the rear tire so that the tire would flex and soak up some of the wrinkles in the road , but he was not a aggressive rider at all , and it had tubes front and rear . My point is obviously 25 psi would be unsafe on a low profile tubeless tire , but sometimes just a few psi can make the needed difference .
If the bike is loaded with rider, passenger, tour pack and gear the side walls of the tire are going to flex more than when there is only the one rider .
#33
I love my bike, and love the look, but the ride is so harsh or firm. How can I improve it without spending a fortune?
I've already changed the rear air shocks to Progressive 944's. That helped a bit, but if I happen to not be paying attention to a imperfection in the roadway I get a spine jarring jolt to my back.
I've test ridden several Ultra's and do not have that issue. I am at the point of replacing my beautiful bike with another beautiful bike. I'd rather keep my SG, but it's wearing me out.
Suggestions and thoughts are welcomed.........
#34
#35
I have an Ultra 90% without TourPak & Solo, Ohlin 3-3's rear, Legend cartridge front, Corbin Solo or stock seat - redone double memory foam front/rear (Mean City Cycles), spoke wheels instead of mags (a little flex), run front & rear tire pressure 2-3lbs low, and it is comfortable as well as handling great. Only issue with tire pressure it is slightly harder to back and push around.
As others stated I came from HardTails and crude suspension, so what we have now are a dream.
cadent47 (09-11-2016)
#36
#37
#39
I have an ultra front wheel that I run on long rides especially. 17inch instead of 19. That extra sidewall cushions the ride, its amazing the difference. Ultra wheels are cheap. I bought mine on ebay with rotors for $250 free shipping. I am a mechanic by trade so swapping is a breeze. When my tour pak goes on the ultra wheel goes on.
