2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
How can I get my SG to ride like an Ultra...?
Old 09-09-2016 | 12:42 AM
vizcarmb's Avatar
vizcarmb
Add 40 lbs of weight. Adding a ballast helps if you want it to ride like an ultra. Just like adding a tour pak
Old 09-09-2016 | 02:03 AM
cadent47's Avatar
cadent47
Originally Posted by senna
What springs do you have on the 944's? Standard or heavy duty?
standard duty springs
Old 09-09-2016 | 02:07 AM
cadent47's Avatar
cadent47
I'm trying to lose 40, not add 40.......
My old '07 Ultra, and the '16 RG ultra I test drove, rode / ride so much smoother. I see a different bike in my future.......
Old 09-09-2016 | 08:25 AM
GTK's Avatar
GTK
You might try a seat modification like the ones that Mean City Cycles do to soften those spine jarring bumps.
Old 09-09-2016 | 08:43 AM
Beaux's Avatar
Beaux
17" front?
My Ultra (16"R, 17"F) rides better ............. my SGS (16"R, 19"F) handles better, both have 12" premiums on the rear.
Old 09-09-2016 | 08:54 AM
BigMike's Avatar
BigMike
This thread is like someone buying a Corvette and asking how to make it ride like a Caddy.
Maybe that is a little overstated, but is there that much lack of common sense? You have a SG and EG that are basically the same exact bike with the only differences being the weight, seat, rear shocks, wheels and tires. It isn't that difficult to figure out how to answer the question. Smh
jd05flhtci (09-10-2016)
Old 09-09-2016 | 08:59 AM
lionsm13's Avatar
lionsm13
Thinking that you probably need to have someone help you adjust the sag on the 944"s.
Try that first before you throw out $$$$$ on a new set.
944's are way better than the stock ones in the Ultra, hands down.
For the front end buy a set of the Progressive monotubes for the front end. Think No More Nose Dive.
Old 09-09-2016 | 09:09 AM
Two Lane Tramp's Avatar
Two Lane Tramp
This is correct!! You would simply be buying the same bike with a different setup. This biggest difference you can make are shocks and tires. I have heard lots of people are willing to trade for your low profile 19" front tire. That alone would make a "huge difference". I keep looking for someone to make a 130/90/19 that will fit my bike so I can keep the 19" and soften the ride a little more.
Old 09-09-2016 | 09:11 AM
jeffreydsilver's Avatar
jeffreydsilver
Originally Posted by englishman
apart from the wheels, tyres have you changed the seat?
Agreed!
Change the seat to a stock ultra takeoff! Problem solved!!
Old 09-09-2016 | 09:17 AM
micmoren's Avatar
micmoren
I just put the heavy duty 944s on my Road King and I have noticed a difference in the ride. I still have to set the correct sag but just out of the box it was an improvement. The Ultras do have that nicely padded seat but I cannot see myself putting one on my RK. As BigMike and TwoLaneTramp have stated, you need to look at a different wheel/tire up front and different seat (once you set the sag correctly on your 944s if you have not done so already). And a little ballast should help as well because I have heard that the progressives ride even better when 2 up. If none of that works, I hear the 2017 models are great. Good luck.
Quick Reply: How can I get my SG to ride like an Ultra...?
