Squealing Noise after Clutch install
I honestly tried to find the answer here but could not. I have a 2015 Ultra Limited with 17K miles that had the clutch go out. The dealer installed a new "performance" clutch per the paperwork. It seems to "grab" quite well and in fact I stalled it a couple of times I rode it after the install.
My question though is now I get a squealing sound when I start out unless I am very very careful and let the clutch out very slow with just the right amount of gas. It's way different than when it was new and I have never had that noise before. Also if taking off up an incline it is impossible not to have the squeal with the amount of gas needed.
Is that the clutch and there is a break-in period or perhaps the compensator working harder because of the clutch engaging so firmly? I don't understand why it would be different than stock when I bought it?
Something is wrong. I recently installed a Screaming Eagle clutch and diaphragm spring. No noise at all.
Squealing sounds are typically metal on metal. I'm guessing they got the disks mixed up and have a metal disk to metal disk.
Take it back to the people that replaced the clutch..and don't take "they all do that", or "it'll go away when it breaks in" for an answer.
Did they put oil in the primary?
There is a ring at the very bottom of the stack on the 06RG clutch that has to go on a specific way. It's the first ring ya put into the clutch bowl when reassembling it. 50/50 chance of guessing it right if you don't look at it real close. I don't know if the 15 model has the same part issue.
Update: The dealer had installed the wrong clutch parts. They put the screaming eagle performance parts in which are not compatible with the FLHTK. I guess that can happen but probably shouldn't. The good news is they did not make me pay the difference for the parts which came to about $100.00 more than the wrong parts. So an extra couple of days in the shop for $100.00 discount is OK.
My question is how the original clutch went out at 17K miles!!!!!???
