Wiring a reckless fairing?
I wired my Rockhoodz (likely same stereo and harness as your fairing) directly to the battery. Easy, and completely isolated from any of the bike's wiring.
There is an un-used connector for a fender tip light you can wire a relay into if you want it switched or get the acc plug. The one in the headlight will have to be turned on by harley using the digital tech. Either way if you are running an amp or putting any kind of load on it you should go back to the battery.
Smcconkey
Electrical/Lighting/Alarm
06-29-2012 11:32 PM
