2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
CB Radio Upgrade Kit
Old 09-21-2016, 11:53 AM
cycle7447's Avatar
cycle7447
cycle7447 is offline
Received 1,961 Likes on 1,197 Posts
Glad that worked for you. Which new antenna did you install?
  #62
Old 09-21-2016, 12:37 PM
MilesOfTexas's Avatar
MilesOfTexas
MilesOfTexas is offline
I contacted Clay at Clay's Radio Shop in Dallas and went with his recommendation of a Hustler QD-27 Center loaded CB Antenna. It's 55" tall. He also carries an adapter to mount it to the factory antenna stud on the tourpak. Darn adapter cost nearly the same as the antenna, lol.
The QD-27 antenna is $27.95 and the adapter is $24.95 and the part number for the adapter is (HD-HARLEY-ADAPT).
The adapter is not on their web site. If you place an order, add a note to the comment box telling them to add the adapter (HD-HARLEY-ADAPT) to the order. They will add the adapter to the order prior to charging your card.
http://www.claysradioshop.com/antennas_center_load.htm
  #63
Old 09-21-2016, 01:06 PM
cycle7447's Avatar
cycle7447
Thanks for the info - god you are getting a much better connection. The upgrade kit made the world of difference for me. Seems like it was all about the grounding.
You r idea is yet another way to go - and certainly less expensive than mine. The ground kit was $101. Hopefully someone here looking for solutions are able to read what we did - and put this to good use.
Thanks again
MilesOfTexas (09-21-2016)
  #64
Old 09-21-2016, 01:16 PM
MilesOfTexas
Thanks again
Agreed! I may yet even add the kit you have.
  #65
Old 10-01-2016, 11:05 AM
COWBOY1296's Avatar
COWBOY1296
COWBOY1296 is offline
Default transmit switch
I just got off of a 2300 mile trip. Only one other guy had a cb on an older Harley. Our range although not measured was just fine and i have the stock antenna. Now this may be off topic, but i find the transmit toggle switch difficult to use while riding down the road. Has there been an upgrade to this switch? Or is there a bike to bike walkie talkie system that is compatible with the rushmore?
  #66
Old 10-03-2016, 06:08 PM
RG Pilot's Avatar
RG Pilot
RG Pilot is offline
It's actually been talked about quite a lot on this forum and there is no alternative for the PTT on the throttle side. It
is really a bad spot for that. The perfect fix would be the odometer switch on top of the left housing.
Olskool53
05-29-2018 05:46 AM
Wayne Carlton
Audio Systems
02-01-2016 10:03 PM
Wayne Carlton
12-16-2015 08:50 PM
Dano.61
06-11-2010 05:32 PM
Lil Truckr
08-15-2007 04:09 PM
Quick Reply: CB Radio Upgrade Kit
