GPS route deletion
GPS route deletion
I don't know if I can explain this but here it goes. I'll put in a route, then after awhile I'll decide to go somewhere else without the help of the GPS. How do I delete the GPS route. I've tried everything, but the voice prompt keeps saying recalculating. I hate this but haven't figured out a way to delete the previous route or all previous routes, so I can listen to the audio sytem without interuptions from the GPS voice prompt.
Thanks Jonnierock
Thanks Jonnierock
Push the (=) button on the right side of the map screen, a list will come up, first item on the list is "stop". Push that.
Any time you select a route and hit the "go" button, the GPS will stay on that route, even if you stop the bike and shut it off and restart it later, until you either reach your destination, OR you stop the route. If you go wandering off somewhere else without stopping the route, the lady will continue to try to find a way to your original destination.
jampg (07-06-2016)
jampg (07-06-2016)
Click or touch the route you want to delete. On the right side between the up & down pointers is what looks like a pencil, click or touch that. Route will change to a window with several options, rename , add waypoint, push the down arrow until delete comes up, click or push delete will ask you if you want to delete, push Yes and trip is deleted.
The following 2 users liked this post by Moe55:
GalvTexGuy (07-07-2016),
striper.seeker (07-08-2016)
