2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
idle noises and erratic behavior
Old 05-28-2016, 06:29 AM
Android's Avatar
Android
Android is offline
Default idle noises and erratic behavior
Is it me or does the 14 idle a bit erratic and noisy as compared to the 2012 103 motors?
Anyone else have noticed this?
Old 05-28-2016, 07:11 AM
jpooch00's Avatar
jpooch00
jpooch00 is offline
My '15 is as smooth at idle as any other Harley I've owned.
Is it the engine temp manager cutting the rear cylinder off at idle? I've kept that feature turned off on mine to avoid the rough idle and noises that you describe.
Old 05-28-2016, 07:21 AM
Sam2010's Avatar
Sam2010
Sam2010 is offline
My 14 is the smoothest I ever had to.
Old 05-28-2016, 08:07 AM
Android's Avatar
Android
Android is offline
No, I am quite familiar with that. It is a rough idle but not in a sense of missing or else. It is hard to describe. I guess I will go down 5 miles to the HD dealership here to let them take a look.
Old 05-28-2016, 08:41 AM
Harttoo's Avatar
Harttoo
Harttoo is offline
When mine was stock it had kind of lope at idle.I liked the way it sounded.When I got an FP3,slip-ons and A/C ,the lope is gone.
Old 05-28-2016, 11:50 AM
todd-67's Avatar
todd-67
todd-67 is offline
Received 3,407 Likes on 1,593 Posts
Mine does...
Old 05-29-2016, 06:41 AM
OldMike's Avatar
OldMike
OldMike is offline
Received 1,927 Likes on 1,260 Posts
I don't have a 2012 103 to compare but the new 103 had a different cam, air cleaner and probably different exhaust.
OR, maybe your bike is acting funny so the dealer can fix all that.
Old 05-29-2016, 09:31 AM
Android's Avatar
Android
Android is offline
Took it to the dealership and yes, it is normal and it is a product of the new cam and the other things they did to fight the heat. It does idle a bit rougher than my 12 103 engine but the 12 103 engine is considerably hotter. So mystery solved and I am a happy camper again.
Old 06-03-2016, 09:25 AM
alarmdoug's Avatar
alarmdoug
alarmdoug is offline
I had the same unsettling issue/question when I first bought my bike almost 2 years ago. Best way I can say it, was a "stumble" in the idle and unsettling noise.
Dealer said it was normal.
However for me it is due to the heat management system turning off the rear cylinder plus the lean run condition in closed loop mode.
I did do a few simple mods, added XIEDs and decatted.
I also disabled the Heat Management System. Your owners manual says its for rider comfort, I didnt find it comforting!
In your owners manual are instructions on how to turn it off.
Takes only seconds by rolling the throttle forward. You can turn it off and on at anytime or just leave it off, as I do now.
Old 06-03-2016, 09:29 AM
MilesOfTexas's Avatar
MilesOfTexas
MilesOfTexas is offline
Change your primary to Formula+. Thought same as you until I did that.
Quick Reply: idle noises and erratic behavior
