Just ordered Malo bars for the RGU..........
Well I just ordered a set of 14" Malo's for the bike....now the wait begins. Called the local HD shop to get a quote on the chizeled bars installed with braided cables at 6.5 hours labor was around $1300 figure I will go with the Malo and save quite a bit of money. They factory 47 website says I can use my stock cables and wires so that's a plus. I'm a bigger guy and I think I will like the extra width compared to the chizeled bars plus my wallet is happy as well.
I'd question using the stock wires. I just installed 12.5 inch bars on my 16 RGS with a little more pull back and the stock switch wires on the right side worked, but were a little too tight for my liking. I purchased the Harley wire extender and I've got plenty of slack. The whole job took me three hours taking my own sweet time. The labor charge by dealers for handlebar replacement is a ripoff.
Yes. For the brake line it helps to disconnect the starter wire (I think that's what it is). Just find the brake line running through the right side under the instrument panel and it will be the wire assembly running under it. It plugs into a mount on the lower right. If you simply run that wire over the brake line and reconnect it you'll get more slack.
As far as the clutch goes, you'll have to cut a wire tie that was darn difficult to get to under the instrument panel at the bottom left. Trace the clutch cable and you'll find it. It was difficult to cut with wire cutters because it's in a tight place. Once cut, it'll release a good deal of slack.
It was easier changing the bars on the RG than the SG I had that's for sure.
