.gpx file issue with NAV
Boom 6.5 on a '14 FLHTK. I Imported 13 trips from BaseCamp into my NAV unit this afternoon. Loaded up each one individually to be sure they came up properly. One of the trips locked up the entire control system of the Boom 6.5. The radio keeps playing but none of the inputs work. I had to shut off the ignition to restart the Boom system.
I went back into BaseCamp and played with the route a bit, re-imported it and still the same thing. I deleted that trip completely from BaseCamp, redid the route, named it something different and imported the new route. Works fine.
I can't even delete the bad trip file from the NAV system because it locks up before I get to the edit function.
Copied from Ghostrider in a seperate thread:
This is out of the 2014 Touring electrial diagnostic manual. Maybe try this? To enter the service menu:
1. Turn IGN OFF. Wait 15 seconds.
2. Press and hold power/mute button. Turn IGN? to ACC.
3. Continue to press power button for 2 seconds after the WARNING screen is displayed.
4. Release power/mute button and accept warning.
The service menu may display Diag Service not Availiable when a menu option is initially selected. This message will clear once the system has finished performing the power-on process. Options are: DTCs, Audio, Display, Key input, Component menus, Version info, Reset, Touchscreen.
Reset: Pre-calibration reset: Restores fatory default settings. This is recommended when there are radio symptoms and no DTCs*
Post calibration save: Archives customers settings so that they can be restored after a Post calibration Reset.
Post calibration reset: Resets the radio to factory default settings and restores the last archive data stored during Post calibration Save. Give it a whirl? Let me know if this works?
striper.seeker (05-16-2016)
Basecamp GPX files can include more information than the Infotainment system needs/uses for routing. I've "cleaned up" GPX files that friends have generated on Basecamp using Route Converter with good success. Garmin units have more options that use the extra info, so there's really nothing wrong with those GPX files, just stuff that confuses the H-D box.
rwven (05-17-2016)
the_ogre25
2014-2023 Touring Models
03-13-2020 02:31 PM
