Exhaust Tape cracking pipes
So I installed SE exhaust tape, approaching summer little extra Heat prevention around my leg..
Then read the posts about cracking pipes
Promptly Contacted Bassani and they said to "...REMOVE the exhaust tape 😡..."
My question was answered swiftly , No good, will crack the pipe....
Received 5,440 Likes
Much easier on the eyes and pipes.
Batman
On a race car I have, the one time I warped the pipes it caused water to be trapped from the heating and cooling cycles. After a few years, I unwrapped them to do some repair when I found that about 1/2 the OD wall thickness was gone because of the pipe rusting and flaking. After that I went unwrapped with a ceramic coating with no problems.
Wrapping the pipe does not allow the tubing to radiate heat, it holds it in the pipe. This subjects the exhaust system to extreme heat which essentially tortures the material and leads to embrittlement. In many cases this can cause cracks and failures, it all depends on the heat/loads the exhaust was subjected to. I have seen cases where we removed a wrapped exhaust and the only thing holding it together was the wrapping.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
The following 6 users liked this post by fuelmoto:
digital (05-11-2016),
GTK (05-14-2016),
hattitude (10-17-2022),
MotoJockey (10-17-2022),
pswomack (10-17-2022),
and 1 others liked this post.
Crazy.. and to think I run a machine shop 😳
Great explanation... Glad I bought my Powervision from Jamie, he knows his stuff 👍👍
Wrapping pipes has been around the hot rod community for decades. I would never do it. It ruins pipes and headers over the years, they dont look all that great, and benefits are minimal. And yes, they will turn ugly over time
I have my hot rod headers and my MC header pipes CERAMIC coated. Its the only way to go. The surface temps are reduced drastically. Be aware, many Powder Coaters and ceramic coaters will not coat used pipes. Many colors avaialble in Ceramics
smitty901 (10-17-2022)
