Security Siren
Received 2,073 Likes
You don't have to have a pager... Here are the instructions to disable the chirp:
Chirpless Mode
In chirpless mode, the siren does not chirp on arming or disarming.
The siren still provides warning chirps and sounds the alarm if motorcycle is moved or ignition switch is turned on without the fob present.
Switching Modes
Quickly cycling ignition switch ON-OFF-ON-OFF-ON switches the system from one mode to the other.
1.With the fob present, turn the ignition switch to IGNITION.
2.When the security lamp turns off, turn the ignition switch to OFF.
3.When the security lamp turns off (but before the turn signals flash twice), immediately turn the ignition switch to IGNITION.
4.When the security lamp turns off, immediately turn the ignition switch to OFF.
5.When the security lamp turns off (but before the turn signals flash twice), immediately turn the ignition switch to IGNITION.
Chirpless Mode
Switching Modes
If the dealer is going to charge you for installing the siren just do it yourself. It's plug and play and instructions are easy to follow.
Chirpless Mode
Switching Modes
Chirpless Mode
Switching Modes
