2016 Clutch issue
2016 Clutch issue
I have a 2016 Ultra Limited with a little over 5000 mi on the clock. It doesn't happen often (bike sitting for a couple of days) but when I leave the bike sit for a couple of days the clutch will not disengage until the handle is touching the grip. This past Sunday after sitting most of the week I started the bike, pulled the clutch in, put it in gear and the bike almost jumped out from under me! Once I've ridden it for awhile it's normal. I mentioned it at my 5000 mi service but the service guy said they didn't find anything. Anybody else experience this?
What your describing is exactly what the last clutch recall was about.
Have you had that work performed?
If not, get it done.
Not even sure if that recall affected the '16 models.
But your description fits the issue listed in the recall.
If you have had it done, take it back and explain it exactly as you did here.
That second recall also extended the warranty on your clutch, so it will be covered.
For the record, I've never experienced any issues with my '15 Limited.
