2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Front and rear brake won't disengage cruise
Old 05-06-2016 | 09:46 PM
RollaMo's Avatar
RollaMo
Originally Posted by rmc115
I had a '14 and have a '16 limiteds, exactly the same issue and nothing like my '10 and '12 limiteds. can't be a problem with both and owner manual says to roll the throttle to disengage. Mike
Since your going to stick with the "owners manual" story, you should have noticed it also states that it disengages with either front or rear brake being applied.
I will say it again, if your cruise does not disengage as soon as you touch the front brake lever or rear brake pedal, there is something wrong with your system.
And as you have pointed out, rolling your throttle forward will also disengage the cruise.
But that doesn't lessen the fact you have an issue if the brake switches won't disengage cruise also.
My '15 Limited works exactly the same as my '11 Street Glide did.
The slightest touch of the front brake lever, rear brake pedal, clutch lever will disengage the cruise.
Oh, and rolling the throttle forward on the "Pre-Rushmore" bikes also disengaged the cruise.
Old 05-06-2016 | 09:51 PM
Hammz's Avatar
Hammz
Originally Posted by gabeodog
Hey all.
I installed a +2 soft brake pedal and went on a 1200 mile weekend road trip.
The first day was in the mountains so i did not use the cruise.
Way home I took the freeway. It was then i noticed my cruise would not shut off with either the front or rear brake. When i got home i checked if the brake light came on when they were depressed, they did.
IDK if i did something on the install
or what?. Don't remember the last time i used the cruise. Not that i have bad memory, just use it so often i don't recall how i disengaged it.
It shuts off when rolled and clutch squeezed.
Any ideas?
You probably don't have any brake lights either...
Old 05-06-2016 | 10:00 PM
rmc115's Avatar
rmc115
Mine will shut off with the brakes, just takes more pressure and is annoying to dip the front forks to disengage. After getting use to rolling the throttle i don't even try the brakes anymore unless emergency situation. Mike
Old 05-06-2016 | 10:07 PM
Punjabi Rider's Avatar
Punjabi Rider
No difference from 05, 07 and 15 disengaging and I always use cruise control regardless freeway, local or sweeping curves due to right hand wrist issues.
Old 05-07-2016 | 07:51 AM
RollaMo's Avatar
RollaMo
As soon as you begin to pull in on the brake lever, the brake light comes on and the cruise disengages. No "dipping the front forks" due to heavy brake action.
If yours isn't operating like that, something isn't right, and has nothing to do with it being a "Rushmore" bike.
Old 05-07-2016 | 09:34 AM
Bagged Out's Avatar
Bagged Out
I found right away with the rushmore's you need a lot of brake lever travel to disengage the cruise, so much that is causes the bike to compress the forks before cruise shuts off. I read the owner manual and saw they say to roll the grip forward to stop cruise, started doing that and works fine. Mike
My 14 SGS is exactly the same. Hard to disengage CC using the brakes. My 09 worked with just a quick tap and the cruise control would disengage.
I use the throttle roll or press the on/off cruise button.
Old 05-07-2016 | 09:57 AM
gabeodog's Avatar
gabeodog
I took it out for a spin to test the theory. It takes a good pull on the front break lever to turn it off. It used to do it with just a slight pull of the leaver.
Now the front fork dips. Rear same way without dip of course.
Thats why I felt it wasn't working because of the amount of pressure needed to dis engage. I don't think it is working right.
Old 05-07-2016 | 03:24 PM
RollaMo's Avatar
RollaMo
It is not working right.
Cruise disengagement isn't tied to brake pressure at all.
It is an electrical switch that sends a signal to disengage.
If the switch isn't working correctly (not sure if it can be adjusted) and requires you to pull the lever in more than normal before it trips the switch, then of course the brakes are going to be applied.
But the switch should trip the cruise off before you even notice any brakes being applied.
Same goes for the brake light. Just the slightest movement of the brake lever trips the switch and brakes lights come on and cruise disengages.
Old 05-07-2016 | 06:27 PM
gabeodog's Avatar
gabeodog
It is not working right..
So now the million dollar question is can it be adjusted?
If anyone knows this would be real helpful.
Old 05-07-2016 | 06:57 PM
speedyrob's Avatar
speedyrob
i just rode 300 miles this morning, used the cruise a lot, just a lite touch of the hand brake lever disengaged the cruise, I would not be surprised if the slight movement it took to disengage cruise was not even enough to kick the brake lights on. You are certain to have a problem, the brake disengage is an essential safety feature, first thing you grab in an emergency stop is brake. Mine is a '15 Ultra.
Quick Reply: Front and rear brake won't disengage cruise
