Gents,
Seems like there is a consensus about changing the oil @ 500mi. I am going to assume that I should put straight Dino back in the crankcase for continued break-in? How about the trans and primary ?
Thanks,
Steve
Put whatever you want in it. The CVO's come factory fill with syn 3. No harm no foul. I use the Amsoil Majik Fluid in all three holes. (EVO)Years ago we ran Penzoil aircraft oil with a cup of gear oil in the engine, then Type F in the primary, (then 10-40) and 80-90 in the gear box.
We used to bring our bikes to an old guy in Louisiana called Campy, and this was his solution and this is what we did... Seemed to work at the time. Not the type F though, that **** would leak out.
