heated grips
heated grips
have a 214 limited wondering if the heated grips can be turned on/off with a new button on the console with the one for the passing lamps.
that is controlled via the computer?
instead of using side of grip to turn them on/off I would leave them on and use this button to power them on/off and the side of grip could be used to set temp making them last longer?
I can see the point.... probably seldom have to change the temp, and the external switch avoids wear on the grip internals.
Good idea.
Good idea.
__________________
NO, they DON'T all do that!
Also on amazon.com...
Yes there is a harness & switch pack that is used to power on and off accessories. It adds 2 switches to the panel on the left (along with Aux lights)
Not sure if this method will make them last longer but, this is how Harley has an option to set them up.
I have the '14 ultra and added the grips to mine when I changed out the bars to Chubby's wild 1's I used this:
http://www.harley-davidson.com/store...11-71400106--1
I used this to bring power to the grips and also used it to power a GPS.
You will need to run the cable under the tank and seat and the harness plugs into the P&A plug in the fuse box.
There is also a harness that can power the grips without switching. I just like the idea of a positive switch to power off that circuit.
Hope this is helpful
Thanks, From us "flat landers"
Mike V
Mike V
I live in Eastern Canada. I'll report back when I wear mine out. It's still an average daytime high of 42 here. If they are a high wear item, I'll have mine warn out soon! I do understand the OP's thinking, but I'm not sure I would be so worried about it as to go to the work to put a switch in. It could also be looked at that if you don't move the switch around every now and then, corrosion could cause it to fail before wear does. Moving the switch will help keep the connection clean. JMTC
