New Head Pipe installation
Ok I am about to pull the trigger on either the V&H dresser duals or the power duals (haven't decided on which way to go yet) for my 15 road glide. the installation looks pretty straight forward. Just want some input on how difficult (if difficult at all) it was to install the new headers. Also getting the FP3 fuel pak and that looks really easy to install.
The reason I ask is because the header to the engine bolts kind of look like a bitch to reach.
I found a u-joint for the socket a must along with an extension. It was a pain but would have been worse without it. Nothing difficult just awakerd.
I to have an FP3 and could not be happier. It dose the basics really easy along with auto-tune but will require studying to go deeper. Unless you know what your doing with tables it looks like a bit of a stretch for me.
I might add I used a decated stock header. Aftermarket pipes may have a different bend by the header studs which may make it easier.
jclax01 (04-12-2016)
I just installed my Power Duals and it's not really that bad. You'll need to install the new heat shields before putting on the new head pipe. One thing you might find confusing is the instructions say to install just the head pipe and finger tighten the flange nuts. Then you'll need to adjust the transmission bracket so the hole lines up with the one near the collector on the head pipe. Tighten one of the transmission bolts that holds the transmission bracket and then you'll remove the head pipe so you can tighten the other bolt that you can't get to when the header is on. You don't need to remove your lowers if you have them (it'll be a hell of a lot easier if you don't though) and I have but didn't need a universal joint either. 1/4 inch torque wrench you will need.
I couldn't get my pipe to seal at the ports. I took it off and reinstalled 4 times and couldn't get it to seal completely. V&H is sending me another head pipe because they believe it's out of alignment. Make sure to check that too with smoke or a small flame.
The FP3 is fantastic. You will like it.
FYI- V&H power duals are common to scrape on hard right handers!
Take off your right floorboards, right fairing lowers (if you have them) order a new set of SE header gaskets.
As well as what was mentioned above.
I personally would choose a different Turner, but that's just me.
Good luck.
YB
YB
I went with the S&S Power Tune headpipes, which still have the crossover. Have a Limited, so the lower fairing wasn't coming off. No swivel socket was used. Wasn't as bad of a job as this forum lead me to believe.
Good time to replace the brake lever with a Softbrake. I went with the FP3 and it's been flawless.
Good luck on the decisions!
thend
Exhaust System Topics
14
05-13-2015 04:07 PM
