Has anyone else considered NOT getting the clutch recall work done ? (besides me)
#31
After I had the clutch recall performed, I looked it all over pretty well for leaks, etc - I didn't see anything at the clutch fluid reservoir nor at the derby cover, but will keep an eye on it.
Its probably a matter of me over-analyzing the bike after the work was done, but on the ride home, it almost seemed like I could feel a slight 'buzz', kinda like a 'non-smooth' road surface would give. Hopefully its just my imagination, but could the 'clutch lift' adjustment step that is performed with the derby open, somehow trigger this sensation ?
#32
From my own experience, they're completely and totally capable of f-ing up a steel ball with a rubber hammer!
#33
The actual issue that caused the recall was that the hacks that assembled the clutch master cylinder unit didn't thoroughly remove all of the final-cleaning solution from the main casting before assembly and the residual solvent reacted with the clutch fluid and caused it to form bubbles.
Nothing to do with the seals or other internal parts.
BTW, the OP had his recall done and had no issues.
#34
how many of you have the same issue???
One member that I know of, who also refuses to let a dealer touch his bike, didn't have the clutch recall done. He flushed the system, installed fresh fluid and bled the system himself. As far as I'm aware, everything is working like it should.
Edit: I don't like having dealers touch my bike, either. However, I did have them do the clutch recall. Of course, shortly afterward, fluid leaked out of the reservoir and caused the paint to start peeling. That's what I get!
#35
I think there is more to the reservoir paint peeling than we all know. Mine looks like there are 2 tiny weep holes in the cover towards the gasket or the this is another defective part HD has used. I personally know of several friends that have the same paint peeling issue. I was planning on bringing this issue to their attention on my next service. I just wondering now how many others have noticed this? It looks like it is leaking a little to me.
No fluid should leak out, but sometimes moisture does. If it leaks actual fluid either take the cover off, clean the seal, tighten it "perfectly" while installing everything back OR just take it in to a dealer.
#36
The two times I've had a dealer touch my bike for service, the 1K along with the clutch recall and the 10K, the clutch reservoir leaked. After the 1K, the brake reservoir leaked, too. So, I don't know if it's a widespread issue or a technician issue. They've agreed to replace the reservoir assembly under warranty. To be honest, I don't know if I should trust that they won't screw that up.
#38
#40
$tonecold
Milwaukee Eight (M8)
17
05-13-2019 02:31 PM
