And the teasing continues. Got home and Fedex left a Fuel Moto present. Only it wasn't big enough for the mufflers. The ac and fp3 are here. Apparently the mufflers were drop shipped and arrive on Monday.
Getting everything else installed today. Just have to ride with the stock mufflers for a few days.
Not sure if you started install yet. I did mine this weekend with the Ceramic coated JP 2/1/2 and Hi Rollers. Pull the right board and install the header without the heat shields on first. You might have to tweak the header a little to get both seated in the ports. Also, use a little WD40 or Liquid Wrench dry lube on the crossover gasket and you can get it on without damaging it.
