Oil and Trans Plug Sealant
It's Loctite 565.... the dealer sells it if you can't find it anywhere else.
It is on the drain plugs from the factory.
For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
I've -NEVER- used any kind of Loctite on my fluid drain plugs (on several different Harleys), and they've -NEVER- leaked or come loose.
Just make sure the O-ring is in good shape and replace it if it's frayed.
I'd suggest that you DO NOT USE a 5/8" wrench on the plugs when you reinstall the bolts.
Instead, use a 1/4" allen wrench. Thread the bolts in BY HAND, and once they're snug, tighten up "pretty good" with your hand. You won't over-torque it with the palm of your hand. I've seen numerous posts here from guys who used torque wrenches putting the bolts back in, and then.... stripped the threads out.
Well, as I said.... it's on there from the factory. Use it or not is certainly up to you.
FWIW.... Not everything with Loctite in the name is a thread locker. In this case I think it's more of a sealer. It hardens just enough that it would probably keep a loose drain plug from just vibrating out.
Good-n-snug is fine, IMO. Never had a leak or stripped threads, and I don't use "sealant" either.
But, to each his own. That's just me.
565 is an interesting compound, its use seems to be misunderstood. Steel and Aluminum do not like each other, so on a new assembly out of the factory its use on the dry plug threads really does make sense. 565 offers lubrication and creates a barrier, acting as a sealer and retainer are benefits as well.
