2016 ultra limited HOT
#51
I agree with LP on this, if they say that the EITMS was the problem because it was turned off, that will be a load of bull crap.
If the fans never come on at all, there is something wrong, either in the ECM or the Temp Sensor/Wiring. This system works basically the same as an automotive system, the Temp Sensor tells the ECM what the temp is and the ECM then turns the fans on.
#52
This sounds like just what I was trying to avoid, BS. After researching this heat mngt system it only turns off the rear cyl so in essence while sitting at a light it will be cooler that's really not an issue I guess, I only noticed the heat on a long ride not sitting in traffic so tomorrow when I pick it up ill have to go through the song and dance. I'll give them the benefit of doubt and ride it. Ive got a 100 mi trip for tomorrow afternoon to see family and it's supposed to be warm so that will be a good test. I'll keep this updated.
