2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Oil Change Tip
Old 03-17-2016, 11:11 AM
bill1nat's Avatar
bill1nat
bill1nat is offline
Originally Posted by Just Me
I like to drill a hole, actually drains more oil out because pounding a hole flares the inside the filter.
I do the same
Old 03-17-2016, 11:24 AM
RG Pilot's Avatar
RG Pilot
RG Pilot is offline
True but if you do this with the bike on the jiffy stand, the filter is tilted down so the oil level in the filter is way below the top once you drain it and that's all you need to prevent the mess.
Old 03-18-2016, 10:44 AM
babygorilla's Avatar
babygorilla
babygorilla is offline
I just use my PIG form-a-funnel, loosen the filter a little till it stops leaking, then twist it the rest of the way off. I don;t bother with the hole punch anymore, if I drip a little the PIG catches it.
ntg433
Milwaukee Eight (M8)
24
11-06-2018 01:19 PM
Teachinator
03-18-2016 08:46 PM
bpd138
04-09-2014 09:32 PM
dohadex
11-27-2011 02:38 PM
cbrenthus
10-02-2011 10:23 AM
Quick Reply: Oil Change Tip
