2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Oil Change Tip
Old 03-15-2016, 04:21 PM
RG Pilot's Avatar
RG Pilot
RG Pilot is offline
Originally Posted by GPHDXLC
I have never punched a hole in the bottom of the filter, great idea, from now on i will.
Yah I tried that last time and it does work well. Easy to punch the hole too.
Old 03-15-2016, 08:13 PM
muddmann's Avatar
muddmann
muddmann is offline
Really good info here. Thanks to all.
Old 03-15-2016, 08:23 PM
rjjj629's Avatar
rjjj629
rjjj629 is offline
You said the o-rings are a common size and available... what size are they?
Old 03-16-2016, 06:05 AM
BlueBeast's Avatar
BlueBeast
BlueBeast is offline
Originally Posted by Ridewva
That's a good idea which I'll try next time, thanks. I've been using paper towel cores and slitting them longwise to place under the filter to direct the oil out to a pan.
No problem, but I think I'll have to try your way next time ... that's a good one too! Plus, the wife and I probably have enough of those on the shelf in the laundry room for 20 oil changes (too lazy to smoosh & toss them, lol.) I could even go high class and line it with aluminum foil so it can't soak through the cardboard if I'm not fast enough. It would also save me from cleaning out my homemade funnel, can just use it and toss it!
The ziploc baggie works great too, I used that routine when I used to have a Miata ... you had to be a contortionist to get at the filter and get it out. It was the ONLY way to do it without making a mess. Just be careful your motor isn't scalding hot when you try that method.
Old 03-16-2016, 06:08 AM
BlueBeast's Avatar
BlueBeast
Believe it or not, even at the dealer they're fairly cheap and no guessing games that way.
Old 03-16-2016, 12:52 PM
Dynamite17's Avatar
Dynamite17
Dynamite17 is offline
Hi, I am traveling now and dont have the info with me, I will check when I return. I think they were #8 (but not 100% sure now) and about $2 for a pack of 10. My dealer wants $1 each, which I can certainly afford but just pisses me off. Use 3 every change.
rjjj629 (03-16-2016)
Old 03-16-2016, 01:23 PM
TNCarters's Avatar
TNCarters
TNCarters is offline
Believe the plug O-rings are a #13 Buna-n. I bought a pack of 100 at Grainger for about $6. I've since heard most hardware stores carry them in the plumbing area. Don't recall the OD and ID but it can be found on the web.
Here's a size post: https://www.hdforums.com/forum/gener...g-o-rings.html
The following 2 users liked this post by TNCarters:
bill1nat (03-17-2016), rjjj629 (03-16-2016)
Old 03-16-2016, 01:39 PM
Ridewva's Avatar
Ridewva
Ridewva is offline
Originally Posted by BlueBeast
No problem, but I think I'll have to try your way next time ... that's a good one too! Plus, the wife and I probably have enough of those on the shelf in the laundry room for 20 oil changes (too lazy to smoosh & toss them, lol.)....
LOL I sympathize because had a Miata also which had to have one of the most awkward filters to access of any vehicle I ever had!
Old 03-16-2016, 09:02 PM
ChristoHD's Avatar
ChristoHD
ChristoHD is offline
Thumbs up
Nail hole in filter before removing - genius! Why didn't I think of that, GREAT tip... and the ziploc bag, another great idea!
I have one of these as well and it comes in VERY handy - and it is very flexible:
Pig Form a Funnel Pig Form a Funnel
Old 03-17-2016, 09:22 AM
Just Me's Avatar
Just Me
Just Me is offline
I like to drill a hole, actually drains more oil out because pounding a hole flares the inside the filter.
Quick Reply: Oil Change Tip
