2 boom questions
2 boom questions
- When I am in radio mode I like to be able to select stations using the Preset select option. (you hit the switch forward and it goes to your next saved station). However, when I am using a USB drive, this sucks and I have to go in and switch to scan mode.
Is there a better way to do this?
- Any word on if they are going to allow us to use Blue Tooth to connect 3rd party headsets (Sena)? Kinda a PITA that you cant.
D.
D.
D.
D.
In response to the Boom system being able to connect Bluetooth to a headset, no there is no way to accomplish this. The system does not have the ability or protocols to do this.
If you check threads by a member cpt_carrera, you'll find he has made this work with an aftermarket setup.
D.
D.
Each function of the radio has its own settings. Radio stations can be set to seek or scan, usb drive can also be set. Check your individual settings.
I just verified...
If I set it to PRESETS while using the RADIO it will cycle through my preset channels when I flip the button.
Then I switch to USB and I have to change it to SEEK to advance to the next song or reply the last one.
Wish this was true, but its not what my unit is doing.
I just verified...
I just verified...
I'm going to have to check mine in the am
Trust me, I hope I'm doing something wrong... but I've been messing with for almost a year... lol...
thank you for checking
D.
