Side Tone, Is It Back?
Do you recall where this is located? I just went through everything I could find in the diagnostic menu and wasn't able to find it.
I'll try to do a search for you at some point to find the instructions to get to that menu.
John
You get to it by powering up the system by turning on the ignition while holding down the power button; as if you're doing a factory reset. Is that where you were? There are options in there that do all sorts of stuff like testing your speakers, etc. Side tone volume is in there but be careful not to change anything else by accident. It's possible that they took side tone volume out in one of the updates once they deactivated it but I saw it in there after the update that cut it off and it didn't work for me even after turning the volume all the way up.
John
John
Yes, it used to be there, but it never did anything (wouldn't allow any changes to sidetone volume to be saved), so removing it seems likely. Still, using the intercom when properly adjusted & setup will provide a sidetone confirmation that your voice audio is being heard by the system (see my post #4 in this thread).
I have my intercom setup like you suggested (14 Limited). That's the only way I use mine. Still I hear no side tone. Are you saying you do?
I was just hoping the new update brought it back. Because without it, your not sure my have the Pitt button pushed correctly. Thanks
See HAMMZ post number 4 on the first page. That's how mine is set up and I do get side tone that way. Make sure your VOX is turned to all the way down so you must press the PTT for it to activate and your intercom must be on at the same time you are using your CB. Basically, you're using both the intercom and CB at the same time that way.
Per Pages 60 and 61 in the Boom Box Owners Manual that I have (2015 Bike) First you select the "Home" Button, then select "Setup" on the screen, then "System Information" on the next screen, and finally "Software" on the next screen. The next screen (The third or the fourth screen, depending on how you count this.) should now show you: "Software Version: Version X.XX.X" (As shown in Figure 42 on Page 61 in my Boom Box Owners Manual.) Where the X.XX.X is a series of numbers.
Please . . . what is the Version number you see on your bike?
