Pro Action rear shocks opinions. if u have em
I installed Pro-action shocks on my 14' SGS this past September. Initially it was worlds better then the stock suspension which was way to stiff for my 140lbs riding weight, but still a little stiff on big bumps. Pro-action walked me through some adjustments with the free-bleed screw and it made a big difference. I only have about 2000 miles on them since, but i haven't thought about my rear suspension again until i read this thread.. so it's safe to say i pretty satisfied with it, compared to my stock suspension where i would think about it after every ride.
I still think i have room for improvements to the ride, but i'm a bit too lazy to play with it. I would prefer something like the Super Shox where its one adjustment, but i guess having more adjustability is a benefit when tuning the ride.
I looked into those revo-a fronts and the only issue I see is that you set the preload internally. What happens if you screw up and set the preload wrong?
I can see why they Did that. It would ruin they styling of the bike having external adjusters on the top of the forks
Glad to read all the positive opinions here. Called my Pro-Action tech from my MX days, talked to him about questions, gave him weights and put in the order. Will have them next week, and hopefully installed by next weekend. Will post opinions once I have them to ride on.
I think they could be a bit softer but very few miles on them 300mi...reil road tracks went well 2 up....
You may have to back off the sweep valve a little but until they break in. That is what I did. Check the little bumper that is on the shock shaft. They ship with it about mid shock. After riding it should be pushed down to where there is just a slight crack of chrome showing. That way you know you are using the travel correctly. Unlike some of the other shocks on the market that have huge bumpers down there that are sort of designed to use that to bottom on Pro-Actions and Ohlins are not.
My question is what dose the sweep valve do turn in (clockwise) dose what?, compared to out (Counterclockwise) I know its not like normal damping adjustment or is it and I'm over thinking it?
TIA
If you turn it counter clockwise it reduces the dampening. If you go clockwise it'll increase the dampening (correct me if I'm wrong). What they told me to do was leave the left side alone and adjust the right side. The good thing is it will only turn so many clicks and stop, so you can't hurt anything or have anything fall out. I recommend if you turn it counter clockwise till it stops count your clicks so you'll know where they had it set for a reference and work clockwise from there till if feels right.
On mine, they had the left shock one or two clicks clockwise and I forgot where they had the right. Right now I have the right shock three clicks clockwise from left. Initially I thought it was one or two.
What I did was turn the right shock all the way counter clockwise and did a test ride and went from there. Like George told me, if you turn it to far clockwise you'll feel it right away. I'm still learning with mine as they get some miles on them.
On the spring preload, George told me and may have told you the same thing so forgive if I repeat it. Slide your bump stop up about half way up the rod and after a test ride stop see where it's at. If its on the bottom you may need to tight up on the spring a couple of turns. Like Todd said if your about 1/8 to 1/4" from the bottom your right on.
TOFTS (07-13-2016)
