2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
brake pads
Old 02-03-2016 | 10:49 AM
nuttbaggerr's Avatar
nuttbaggerr
Default brake pads
*my laptop is fubar, I don't have a desktop, and I dont know my smartphone is not sart enough to allow me to use any forum search feature, thus my question here...with apologies*
I will be replacing the brake pads in all three calipers of my '15 RGS with 22,000+miles on the odo that was rolled in one year
I'd like to hear your brake pad suggestions and the feedback/opinions of your prefered choice. I'm not shy about using my brakes lol. Do I stay with oem or go with ????
Old 02-03-2016 | 11:22 AM
Gwaxley's Avatar
Gwaxley
Your not going to find any better than the oem Brembos.
Old 02-03-2016 | 02:02 PM
SpiderPig's Avatar
SpiderPig
Can anyone tell me what the difference is between the fronts and the rears? I have pulled them both and they look identical. These are oem as well.
Old 02-03-2016 | 02:05 PM
Roadblock_MN's Avatar
Roadblock_MN
shop around. You can find MUCH better pricing. I purchased pads from online and they are the EXACT same thing the dealership gets you for WAYYYYYY more....
Old 02-03-2016 | 02:16 PM
BigEd04's Avatar
BigEd04
Care to share where?
Old 02-03-2016 | 02:18 PM
Roadblock_MN
I actually took a chance on some on amazon. When I got them, they were exactly what my buddy got from HD....I paid 1/3 of what he did....
I have not had a single problem and have 8800 on the bike so far and they look to last another summer...
Old 02-03-2016 | 02:24 PM
rwven's Avatar
rwven
I've always installed EBC HH pads on my bikes at replacement time. They run $25.23 a caliper on Amazon.com for a Rushmore FLHTK.
Old 02-03-2016 | 02:32 PM
nuttbaggerr
The OEM kits have a template to place on the back of the pad so you can spread the anti-squeak goop on it where the piston will make contact to avoid the dreaded squeak. The aftermarket don't have it....just pads. I don't need a template and I can figure out where the piston will contact on the back of the pads. What are you guys using for anti-squeak goop?
And what are the opinions of the DP BRAKES #DP962s? Would these no dust-no-noise-no-fade pads have a negative effect on the rotors vs the OEM Brembo pads?
Old 02-03-2016 | 07:40 PM
Harttoo's Avatar
Harttoo
[QUOTE=nuttbaggerr;14804958]The OEM kits have a template to place on the back of the pad so you can spread the anti-squeak goop on it where the piston will make contact to avoid the dreaded squeak. The aftermarket don't have it....just pads. I don't need a template and I can figure out where the piston will contact on the back of the pads. What are you guys using for anti-squeak goop?
I have not used anti squeak goop.My brakes never squeak.My 2012 was hopelessly squealing.Tried 3 different brands of pads.All squealed including
Lyndall.I am convinced that the rotors caused the squealing.
Old 02-03-2016 | 08:18 PM
Sunnyday91360's Avatar
Sunnyday91360
Quick Reply: brake pads
