2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Boom Software v1.19.2 2/1/2016
Old 02-02-2016 | 09:00 PM
AlanStansbery's Avatar
AlanStansbery
Originally Posted by dedjr67
Hopefully it addresses the AVC issue that some of us have
Amen, brudda!
  #52
Old 02-03-2016 | 01:21 AM
Ozbernie's Avatar
Ozbernie
Originally Posted by IdahoHacker
Make sure you download the correct version.
If you have the BOOM Box 4.3 Infotainment system, you should download the "Standard Radio" file.
If you have the BOOM Box 6.5GT Infotainment system, you should download the "Premium Radio" file.
If you're using the correct download, make sure you can see the swdl_boombox_6.5GT.iso or corresponding 4.3 file. If you can't see this in your USB thumb drive, it won't work.
If you're using the correct download, and you can see that file in your USB thumb drive, then it should work.
The software update I have downloaded is for USA bikes, and I am in Australia. The Aussie HD site is only offering the v1.19.1 version. That may be the problem?
  #53
Old 02-03-2016 | 02:18 AM
plasmadaddy's Avatar
plasmadaddy
Yup, that's exactly the problem.
You need to use the "International" update in order for it to work.
Here's the link from the GB website - you'll see a "rest of the world version" which should work:
http://www.harley-davidson.com/conte...otainment.html
I had the same problem here in the UK a year or so ago!
  #54
Old 02-03-2016 | 06:15 AM
AlanStansbery
Originally Posted by GlidingJoe
Some think they have a AVC issue, such as myself till I learned..... When I removed my amps and added an aftermarket amp which many have done, the radio is flashed for an amp to get rid of the DSP, the AVC no longer resides in the radio it resided in the AMP.. Hence the fact it no longer functions...
Ahhhh. I knew my AVC quit at the same time I upgraded to the Stage 1 amp. I figured it was the 'factory' download. But I didn't understand the download was meant to do this. Thanks for clarifying. BTW, who explained this to you? My dealer was clueless, and this is the first note about it I've seen on this site...
Thanks,
Alan
  #55
Old 02-03-2016 | 06:22 AM
lp's Avatar
lp
Just popping back in to say that the radio is working great. AVC and last media included. So much nicer.
It still takes awhile for it to boot up but beyond that, no issues.
  #56
Old 02-03-2016 | 06:50 AM
steelerdude1's Avatar
steelerdude1
OP, Thanks for the heads up on the new update. Going to give this a go today, hopefully it fixes some of my issues.
  #57
Old 02-03-2016 | 07:47 AM
Harley Convert's Avatar
Harley Convert
Under "Radio Fixes" it says Road Glide Picon cut off. Anyone know what this means?
  #58
Old 02-03-2016 | 10:35 AM
! rock103 !'s Avatar
! rock103 !
Has to do with the screen display (picture icons or 'picons')viewability I think.
  #59
Old 02-03-2016 | 10:58 AM
HazyHog's Avatar
HazyHog
OP, thank you for the alert. I like to keep my system up to date.
  #60
Old 02-03-2016 | 11:35 AM
IdahoHacker's Avatar
IdahoHacker
Thanks for the helpful info!
Quick Reply: Boom Software v1.19.2 2/1/2016
