Boom Software v1.19.2 2/1/2016
#281
Start bike, choose, Artist and then an Album. Plays fine. Shut the bike off and the song that was playing resumes. Next song, some random song on the thumb drive.
Also, next track, last track. does not work.
Hope the next update works better. HK, your software engineers and regression testing suck *****.
#282
#283
Select Home, Media, Menu and uncheck "Shuffle".
Select Home, Media, Menu and make sure it says SEEK ,not PRESET.
Most of the complaints users are having, can all be corrected by making some setting changes.
#284
If you don't want it to do that, turn "Shuffle" off.
Again, a setting you can control.
I get it, I'm typically one of those guys that think they don't need instructions. (I used to call them, the jokes) . I have come to realize that a lot of the newer technology really requires the use of the instructions. Suck it up, take it on the chin and rtfm
#285
I have mostly positive things to say about the new update. I had the same issue with the moving songs track to track but was able to fix it by making sure seek was set. No big deal.
I did see one issue though and I can't figure it out. I ride in a lot of group rides and we talk on the CB quite a bit. Now, when people use the CB, my media completely locks up. It won't start for anything unless I go to menu and hit seek. Problem is, that's a pain every time, moves the tracks up a couple and if you like the song, you have to toggle back. Wouldn't be a huge deal but happens all the time. My first ride, it happened every time someone toggled their CB. The second time, it seemed to be working ok and then started doing it more frequently again. I have another friend and he said the same thing is happening to him. Maybe I'm missing a setting? Not sure but this never happened before and now happens all the time.
#286
http://www.harley-davidson.com/conte...Boom_OM_EN.pdf
#287
No "setup"
I have downloaded 4.3 numerous times. extracted the two files. there is no "setup" file or .iso. What am I missing.
Thanks in advance
TnTigah
EDIT: Just got through upgrading. I had to download off of Harley site instead of this forum.......
Thanks in advance
TnTigah
#288
The file you download has a .zip extension.
You extract (unzip/uncompress) that file into the file 2 files.
What two files do you end up with?
I just downloaded the 4.3 version and confirmed it has the correct two files.
One should have an .iso extension
The other one is just a small text file with the .txt extension.
swdl_boombox_4.3_DOM.iso
swdl_boombox_4.3_DOM.txt
The .iso file is the one you want to copy to your thumb drive
#289
Has anyone had the problem of advancing tracks while playing music off a thumb drive? This just started with this update.
I have had to shut the bike down and restart for the joy stick on the left to advance to the next song.
I have also had a problem before and after the update where the head unit wont see any media. Could this be the thumb drive causing this problem?
