2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Boom Software v1.19.2 2/1/2016
Old 02-22-2016 | 07:41 AM
biglew55's Avatar
biglew55
Originally Posted by jjkrueg
My gps clock won't change. Last time I had the bike out was before the clocks went back an hour but the weather was great here so I got it out. Did the update but the clock was always an hour ahead, anyone else have this issue?
In the "Clock Settings" is a setting to toggle between Daylight Saving and Standard times. I think it's the first selection on the page, after the offset selection at the top.
Even on "GPS time", it doesn't automatically offset for DST/STD time.
Or give it a few weeks and it will be right again.
  #222
Old 02-22-2016 | 11:28 AM
sailmotion's Avatar
sailmotion
Unlike a standard $3 digital clock which will automatically switch between DST and standard time, the Boom system must manually be switched; merely setting to DST is insufficient.
  #223
Old 02-22-2016 | 07:14 PM
cycle7447's Avatar
cycle7447
sailmotion - I don't think that is correct. Setting the DST does indeed change my gps clock. So does crossing time zones.
  #224
Old 02-22-2016 | 07:49 PM
jjkrueg's Avatar
jjkrueg
I think that's the point. I changed the DST setting & it changed the gps clock to the correct time. Seems like the point of a gps clock would be to never have to touch it. Oh well, I had a hunch this was the fix but had hoped the gps would fix itself.
  #225
Old 02-23-2016 | 03:14 AM
Hammz's Avatar
Hammz
The only way your $3 digital clock will automatically switch between DST & regular time is if it includes a calendar function (needs to know day & month at minimum) that has DST set & reverts dates defined.
The Infotainment system contains a clock, not a calendar. It knows time, not date. With nav, it also knows time zones, but still not calendar. The user must tell the system if it should use DST or not. It will correct for DST if told to use DST.
See item 5.
  #226
Old 02-23-2016 | 08:30 AM
sailmotion's Avatar
sailmotion
See post #225, instruction #5.
  #227
Old 02-23-2016 | 08:41 AM
sailmotion's Avatar
sailmotion
See item 5.
Sorry. I guess $3 was an exaggeration - but how about $8.75?
Amazon.com - XREXS Large LCD Digital Timer Foldable Desktop Tabletop Calendar Temperature Digital Alarm Clock(silver) - Amazon.com - XREXS Large LCD Digital Timer Foldable Desktop Tabletop Calendar Temperature Digital Alarm Clock(silver) -
...and I'm not sure which GPS system you are using, but it appears that all my GPS units correctly state date as well as time and location [that is, except the Boom 6.5].
  #228
Old 02-23-2016 | 08:58 AM
plongson's Avatar
plongson
Sounds like someone just wants to be pissed off...
Take a page from Easy Rider and throw your time (watch) away...
  #229
Old 02-23-2016 | 09:11 AM
sailmotion's Avatar
sailmotion
Not really "pissed" - more frustrated. I find it intolerable and offensive for a company to market something as the greatest thing since sliced bread [and charge $1,000+ for the "upgrade"] and yet they can't get the thing to work properly.
And I have taken a page from Easy Rider - I don't wear a watch [but I do confess that I can get the time from my cell phone if it's urgent].
  #230
Old 02-23-2016 | 04:55 PM
paulmj's Avatar
paulmj
Here in the UK I've set the time signal to Radio Data Service rather than GPS and DST is automatically applied. Is there an equivalent of RDS in the states you could use instead?
Quick Reply: Boom Software v1.19.2 2/1/2016
