Boom Software v1.19.2 2/1/2016
#171
I can do that as well and it usually comes up ok, but sometimes not.
If I let it go to the accept screen, it always comes up as it should.
We know that not all Boom boxes are created equal, some work better than others. What makes it difficult is wading thru all of the misc. information from various sources using different techniques then reporting "facts" that are not necessarily true.
Like I said earlier, do what you want. Mine is one of the ones that works well. Yes, the fader did not seem effective for a time. Yes, I had the map zoom issue and yes I got bad turn information occasionally. Waiting for the accept button got me consistent startups and no intermittent, flaky behavior. Happy camper here.
#174
Nope . . . go to Amazon.com or similar and buy a cheap 8GB but no larger than 32 GB USB Flash Drive. Search for "8gb usb flash drive" and you'll find quite a selection . . . many for less than $1.00
#175
#178
I installe the update a while age no issues with line levers and I have 2...Now as far as the software update the jury is still out IMO
#180
Installed the latest update & lost a LOT of bass & low/mid on my system. That system being BT 7.1s, MM651s, BT4180 amp, LL's, etc. Also noticed that the "repeat" function on the NAV stopped working.
Back to 1.18.3 & everything is good again.
For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
