2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Boom Software v1.19.2 2/1/2016
Old 02-11-2016 | 08:00 PM
YPD485's Avatar
YPD485
Originally Posted by SafetyMan
The problem there is when you hit the starter, the stereo reboots anyways, so you are not solving any actual issue, only the ones you perceive...
I never wait, and mine is functions perfect. As soon as the fuel pump shuts down, I hit the go button.
Only problem I had in the past was stereo wanting to start on FM when I had it on iPod..
The new update seems to have solved that.
If your sound system reboots even after you have the ignition switch in the accessory position, and the accept screen comes on, and starting the bike reboots the system again, your battery might be getting weak. Mine started doing that and a new battery cured that problem.
Then again, the way the rushmore systems are, they all don't seem to act exactly the same way. So who knows.
  #162
Old 02-11-2016 | 09:30 PM
merdahl's Avatar
merdahl
I always wait for the accept button before starting. Never had an issue since 1.7.4. If it did reboot when starting you would see the accept button again so that is not the case. Do what you want but the system works great if you just give it the time it needs. At stops, I leave the acc on so no waiting.
  #163
Old 02-12-2016 | 05:59 AM
big papa AZ's Avatar
big papa AZ
Since the last update I have had no "no start' radio occurrences, wait or no wait. I think last update had the Hi Vis color option that was a plus in bright sunlight. Everything finally works the way it is supposed to...
  #164
Old 02-12-2016 | 06:23 AM
Bluehighways's Avatar
Bluehighways
Originally Posted by RollaMo
Not buying it.
I have never once waited for the accept screen.
Not sure why or who started that myth.
Step 1: Turn ignition to on
Step 2: Hit start button
Step 3: Get on and ride off
Within a few seconds the accept screen pops up, and you just push the right joy stick button in, which functions as "accept".
Absolutely no need to sit and wait for the boom system to completely boot up.
Absolutely! If you're going to wait until the entire Boom System is up and running . . . including the NAV . . . . you'll be sitting there for a bit. As long as the Oil Pressure Light is off, I'm good to go!
  #165
Old 02-12-2016 | 08:06 AM
Joltergeist's Avatar
Joltergeist
If I don't wait, my front wheel doesn't get completely round, and I wobble all over until I hit Accept...
  #166
Old 02-12-2016 | 05:08 PM
Prairie Shark's Avatar
Prairie Shark
Not buying it.
It's no myth. If yours works without waiting for the compete boot sequence consider yourself lucky. If I don't wait, it comes on in weather band or AM radio - neither of which I ever use and it comes on LOUD. It does that whether it was turned off before I shut off the bike or not and it doesn't matter what media I was using when I shut it down. That's only one of the issues.
On my buddy's bike the joystick won't work if he doesn't let it boot up.
If I let it do the the full boot sequence it works fine.
  #167
Old 02-12-2016 | 05:33 PM
plongson's Avatar
plongson
Just tested mine and it works fine just hitting the start button and NOT letting the "BOOM" boot. No problem here...
  #168
Old 02-12-2016 | 06:48 PM
RollaMo's Avatar
RollaMo
You should go back and read your Boom owners manual then.
Sorry your not able to adjust your settings to make everything work.
  #169
Old 02-12-2016 | 07:00 PM
Prairie Shark
Yeah, that's it I guess.
No wait, I have read it. Several times and I'm pretty tech savvy, my job demands it.
My humblest apologies to you RollaMo for pointing out a flaw in a product from the MoCo. I now realize we aren't supposed to do that.
  #170
Old 02-12-2016 | 07:07 PM
CVO SG's Avatar
CVO SG
I don't have a USB stick, could I plug my laptop directly to the bike to update?
Quick Reply: Boom Software v1.19.2 2/1/2016
