Boom Software v1.19.2 2/1/2016
#131
I cannot get this update to work for me. No matter what I do, and since I have never had this issue in the past... I am growing increasingly frustrated.
Here is where I am before the trolls start rolling on me.
Using a macbook pro
6gig memory stick formatted to MS-DOS (FAT32)
I have downloaded the correct file (swdl_boombox_6.5GT.1.19.2) since I have a Road Glide Special with the 6.5 set up
Every time I try the update... "The ISO image on the attached USB is corrupt or incompatible".
Either I am missing something of this USB stick is trashed.
Open to helpful ideas on the matter.
Using a macbook pro
Yes it includes previous updates
#133
Using a macbook pro
Using a macbook pro
Did you unzip the downloaded file before copying it to your memory stick?
The file you download is a .zip file.
1. Download the file
2. Once downloaded, double click on that file and it will create a new folder.
3. Inside that new folder will be two files (The actual file you need and a text file).
4. Copy the .iso file to your memory stick and go from there.
#134
This particular flash drive has worked for me in the past, so size shouldn't be the issue. Just assuming my drive is shot and I need to pick up a new one.
#135
#136
#137
Right click on the download link and select copy link. Paste the link into your browser and change the filename from 1.19.1.2 to 1.19.2
#138
Using a macbook pro
Using a macbook pro
#139
Using a macbook pro
Using a macbook pro
