Fork oil change.
![Talking](https://www.hdforums.com/forum/images/icons/icon10.gif)
I was reading through the service manual for my 2015 FLHTK and noticed there is no maintenance schedule for the fork oil. HD recommends a rebuild at 50,000 miles. I hate to let it go that far but since they eliminated the drain screws on the lower legs, it doesn't seem like there is a real easy way to change the oil. I've only got a few thousand miles on the bike but I was curious if any one has figured out a way to do a fork oil change on the Rushmores without tearing apart the whole front end? I've got nothing else to worry about this time of the year in the Northeast.
I have dropped the forks on my 04 and on my 15 - The 15 is Super easy,,, The Only reason to remove the outer fairing is to unplug the fender tip light.. other than that, remove fender / wheel / ing switch - the small cover that is under the ing switch - two pinch bolts and it drops down... Very easy..
